Several options for VAT rates of a legal entity
Make it possible to enter several bid options in the VAT field of the "Legal entities and details" directory.
Also to be able to change this rate in the process interface.
Dydyk Ihor
ПП
Or add the ability to edit the VAT rate in process products.
14.12.2022, 09:43
Didik Igor wrote:
Or add the possibility of editing the MPE rate for the products of the process.
you can do it now
VAT amount can be specified differently in each product
14.12.2022, 12:19
Dydyk Ihor
ПП
Ustimenko Igor
OneBox production wrote:
you can do it now
the amount of VAT can be specified differently for each product
The amount of VAT can be edited in the product card.
And how to edit the process in the product (the product may have different VAT rates)?
14.12.2022, 12:36
Dydyk Ihor
ПП
To solve my question, please add the VAT (%) field (producttaxvalue) to the action 'Copy process product fields' -> `Write the value to the process product field:'
15.12.2022, 11:18
give the process where the VAT column of the product is displayed
21.12.2022, 20:28
Dydyk Ihor
ПП
Ustimenko Igor
BP - https://smile.1b.app/134/
Action templates in the procedure - https://smile.1b.app/app/workflow/8/procedure/44/
1. Calculate and record the value in the additional field (For the VAT rate)
2. Copy process product fields (For VAT rate)
22.12.2022, 09:29
display the VAT size column - now I see that it can be edited
24.01.2023, 23:16
