Action once per minute: Import processes with OKop
Setting: Add "Together cheaper" to the discount amount
For example,
1. [file]10627[/file]
2. I click "save" or go to the stage
3. Discount disappears [file]10628[/file]
You can test here https://rivcont.info/2452762/
Action once per minute: Import processes with OKop Setting: Add "Together cheaper" to the discount amount For example, 1. 2. I click "save" or go to the stage 3. Discount disappears You can test here https://rivcont.info/2452762/
Displayed the field "Amount of discount" in the final part The action of importing orders is good with the "Add "Together cheaper" to the discount amount" setting enabled creates a discount https://rivcont.info/app/discount/6/ 1. Order https://rivcont.info/2473447/ 2. We see a discount with a value of 0% 3. In the amount of the discount, we see the desired difference 4. Save 5. Overwrites to 0 anyway
4. Save
I found a field that, in theory, knocks everything down. "Discount amount (manual entry)". You need to display it in the "Final part of the process" block
