finalize the BP action "Calculate and write the value to the additional field if the conditions are met" (add base64_encode() and sha1() functions)
to the action "Calculate and write a value to an additional field if the conditions are met"
need to add the ability to use the functions base64_encode() and sha1()
Перегіняк Олександр
Oneboxconsulting (интегратор)
Administrator wrote:
1 hour of refinement
OK. issue an invoice
02.12.2020, 16:43
Перегіняк Олександр
let me know when the revision will be ready, please?
08.12.2020, 10:46
Until 11.12 inclusive.
09.12.2020, 13:58
They took the time to do it ahead of time.
09.12.2020, 16:33
Перегіняк Олександр
it looks like you have terminated the project https://crm-onebox.com/en/support/business-processes/4298-popravit-otkritie-stra... )) . the problem appeared after your post
09.12.2020, 17:12
Перегіняк Олександр
can you screenshot?
I configured in the action like this - triggering the procedure with the action gives an unrecognized error
10.12.2020, 10:47
I configured in the action like this - triggering a procedure with an action gives an unrecognized error
Well, how would you declare arguments in functions you need in single quotes
10.12.2020, 13:22
Перегіняк Олександр
did like this - the error remained
like this now 'sha1([commentariy1])'
May I ask you to write how it should be?
10.12.2020, 14:21
I wrote about the arguments inside the function
which means like this sha1('[commentariy1]')
10.12.2020, 14:31
Перегіняк Олександр
thank you, it worked!
and you do not plan to write here that these functions are available for use and at the same time that you need to specify arguments in single quotes?
10.12.2020, 14:46
and you do not plan to write here that these functions are available for use and at the same time that the arguments need to be specified in single quotes?
I can add these functions
about arguments - it's trivial for those who want to use functions like this
10.12.2020, 14:56
Перегіняк Олександр
10.12.2020, 15:03
Перегіняк Олександр
OK. Thanks! understood you!
10.12.2020, 15:04
