HELP! When you go to the stage, all the buttons are gray and just freeze https://crm.hlr.ua/
Process https://crm.hlr.ua/admin/customorder/issue/3490997/edit/
when you click on almost any button, the process freezes and that's it
For example, the button Issue a RFP here the action of checking the fields is configured (in the procedure https://crm.hlr.ua/admin/shop/workflow/18/procedure/174/?status=0 ) and a ban if the client is an individual - but I I don't get an error, I just hang. I'm adding a video. You can also switch the process
Such a problem in any process where there is a check for the fields being filled. Please check as soon as possible - work has stopped
Good afternoon. Everything should be fine by now
09.02.2022, 12:50
yes, thanks for the speed, it works now
09.02.2022, 13:23
