1. I try to confirm the order
2. The order hangs in an attempt to change the stage within 3 minutes
3. I try to refresh the page and repeat pressing "choice of payment 16:00"
4. Gives an error that the stage change has already been made
Example: https://rivcont.info/2710641/
1. I try to confirm the order (with the checkbox "create TTN manually" - in order to proceed to the stage where there are no actions for automatic formation of TTN)
2. The order also hangs (a problem with boxing and changing stages)
Example: https://rivcont.info/2710633/
See what's the problem
No opportunity to work
Please delete the attached file after viewing.
1. I try to confirm the order 2. The order hangs in an attempt to change the stage within 3 minutes 3. I try to refresh the page and repeat pressing "choice of payment 16:00" 4. Gives an error that the stage change has already been made Example: https://rivcont.info/2710641/ 1. I try to confirm the order (with the checkbox "create TTN manually" - in order to proceed to the stage where there are no actions for automatic formation of TTN) 2. The order also hangs (a problem with boxing and changing stages) Example: https://rivcont.info/2710633/ See what's the problem No opportunity to work Please delete the attached file after viewing.
