In the task https://ukrpromspec.com.ua/client/order/209615/#done, the client cannot proceed to the "Generate total price" stage. I could before. The access rights to the client did not change. I can switch from admin access to a similar task. You can try the test problem.
And what is the error when going to the stage? Most likely, at this stage, you have an action set that needs more access than you can give the client. What actions do you have configured at the stage?
