Action "Add process products to/from lookup(s)" adds all entries from the lookup if the process field being checked is empty
The action "Add process products to/from lookup(s)" is configured; check against the additional field of the process [file]11961[/file]
Field is empty in process [file]11962[/file]
After switching to the status, the action added all products from the catalog
https://aromacarlux.crm-onebox.com/admin/customorder/aromacarlux/15325/edit/
[file]11960[/file]
Action "Add process products to/from lookup(s)" adds all entries from the lookup if the process field being checked is empty The action "Add process products to/from lookup(s)" is configured; check against the additional field of the process Field is empty in process After switching to the status, the action added all products from the catalog https://aromacarlux.crm-onebox.com/admin/customorder/aromacarlux/15325/edit/
Actually a counter question - why are you launching an action with an empty field? Some clients fill out only the required fields on purpose - and search only for the completed ones. As a solution - before the action, you can use the action "Stop performing the following actions when conditions are met" before the action and specify in it a check for filling the field
Tyndyk Maxim Vadimovich OneBox production Administrator wrote: Actually a counter question - why are you launching an action with an empty field? Some clients fill out only the required fields on purpose - and search only for the completed ones. As a solution - before the action, you can use the action "Stop performing the following actions when conditions are met" before the action and specify in it a check for filling the field
From the site, from 1 to 5 options can arrive, and depending on them, you need to add the required number of products. I solved the issue, with the action "Fill the process field" I fill it with the value "1" only if the field is empty and then the values \u200b\u200bare not the same and the product does not add
OneBox production
