Product search in progress searches by name only in the primary language
Сидорчук Валентин Гарийович FOP Sidorchuk Valentin Garievich
Good afternoon, is the appropriate field selected in the search field settings?
12.09.2025, 13:39
Андрій
CEO, owwa.com.ua
Yes, if I understand correctly, such settings are available in the global search, but we are talking about searching for products in the process of adding them to the product table.
I am attaching screenshots of the global search and results.
12.09.2025, 14:30
If I copy the entire product name into the query, does the search work?
12.09.2025, 15:41
Андрій
CEO, owwa.com.ua
Sydorchuk Valentyn Gariyovych
No, it doesn't work.
12.09.2025, 16:02
Is the search configured in the "Products" application on your screen, or is it also configured in the business process application in which you need to pull up products? Because if you don't search by the full name, the search doesn't happen at all.
12.09.2025, 18:42
disable the setting
Search only by product name and ID using Fulltext principles
22.09.2025, 17:09
Андрій
CEO, owwa.com.ua
turn off settings
Search only by product name and id using Fulltext principles
Great, thanks - it helped!
22.09.2025, 17:11
