There is an action "Copy the field value to the parent process or to the specified process", it is suitable if the current process has the process number written somewhere where to/from where you need to copy https://monosnap.com/file/bXx5G9Qmug2Il2OBVS6MzhSnT6X49b
Mulach Marina Anatolyevna SheBo wrote: There is an action "Copy the field value to the parent process or to the specified process", it is suitable if the current process has the process number written somewhere where to/from where you need to copy https://monosnap.com/file/bXx5G9Qmug2Il2OBVS6MzhSnT6X49b
I know about this, but it’s not that.
Polupan Serhiy Polupan wrote: Is it possible to get a calculation error from the developers regarding the revision?
Good afternoon. Can you please provide a more specific algorithm for finding the process from which to copy fields?
Polupan Serhiy
Yes, I mean a good algorithm, but in principle you already have it implemented. That is:
There is an action "Copy field value to parent process or specified process"
This action has an option (shown in the screenshot) "Exchange data with the specified process instead of the parent"
Do this, similar to the action - "Copy field value from parent process"
What will be the price of such a modification?
[file]24592[/file]
[file]24592[/file]
[file]24592[/file]
[file]24592[/file]
[file]24592[/file]
[file]24592[/file]
[file]24592[/file]
[file]24592[/file]
[file]24592[/file]
[file]24592[/file]
Polupan Serhiy Polupan wrote: What will be the price of such a modification?
2 hours Invoice?
Yes, put it on display.
Maksym Vadimovich Tyndyk
OneBox production wrote:
Polupan Serhiy
2 hours
Invoice?
Polupan Serhiy Polupan wrote: Yes, I mean a good algorithm, but in principle you already have it implemented. That is: There is an action "Copy field value to parent process or specified process" This action has an option (shown in the screenshot) "Exchange data with the specified process instead of the parent" Do this, similar to the action - "Copy field value from parent process"
Good afternoon. Implemented a similar settings block "Exchange data with the specified process instead of the parent" in the action "Copy field values from the parent process" Uploaded to askoart.1b.app, will be uploaded to other projects automatically at night.
Polupan Serhiy
