We have an action: Calculate and write the value to an additional field if the conditions are met
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
The goal for each row is to perform a calculation using the formula and write it in the corresponding fields of each row, provided that two conditions are met for each of them.
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
How it works now:
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
We created a procedure and added several actions to it: Calculate and write values to an additional field if conditions are met, which should be executed sequentially for each row under certain conditions
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
In fact, the calculation is performed only for the last action in the procedure, and an error is issued for all previous actions.
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
On the screens of the action settings and what the calculation result looks like in the problem
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
It looks like there should now also be a check mark next to Do not overwrite value if specified.
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
Because it is with this setting that the values calculated by previous actions remain.
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
Please help me understand the settings. Because each row should have its own formulas triggered by fulfilling conditions based on values in certain cells of the row. But in fact, it doesn't work that way.
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
[file]24567[/file]
[file]24568[/file]
[file]24569[/file]
[file]24570[/file]
[file]24571[/file]
How it works now:
