https://askoart.1b.app/36336/ - process for verification
[file]24301[/file]
https://askoart.1b.app/app/customobject-1/ - reference
[file]24301[/file]
https://askoart.1b.app/app/workflow/143/procedure/795/ - this procedure should work, but it doesn't!
[file]24301[/file]
The directory ID field is filled in (shown in the screenshot), but it does not pull data from the directory.
[file]24301[/file]
[file]24301[/file]
Good afternoon, id is a basic field in the directory, you need to link https://askoart.1b.app/app/customobject/1/field/ add. field with one of the created fields for this action to work.
He drinks fuel like it's free OneBox production wrote: Good day id is a basic field in the directory, you need to link https://askoart.1b.app/app/customobject/1/field/дод. field with one of the created fields for this action to work.
That's right. Everything was done as you wrote. Added field "Id type of services, products (dp)" - "Idtipposlugproduktivdp" is linked to the directory https://askoart.1b.app/app/customobject-1/ field "Id". Why doesn't the procedure work?
https://askoart.1b.app/app/customobject/1/field/ is there an id field here??? I clearly wrote that id is not in this list, so you don't need to bind to it, because this action doesn't work with it.
He drinks fuel like it's free OneBox production wrote: https://askoart.1b.app/app/customobject/1/field/ is there an id field here??? I clearly wrote that there is no id in this list, so you don't need to knit with it, because this action doesn't work with it.
I see from the link, now it's clear. Thank you!
