Subprocesses
Good day!
Product subprocesses in orders are no longer created
Have there been any updates to the box or what could be the problem?
Good afternoon
Unfortunately, your description doesn't make the problem clear.
Please provide an example of the process and settings that can be used to check for the problem.
07.04.2025, 11:03
When moving to a stage, a subprocess must be created
Everything worked before, no changes were made.
There are several such business processes and they all stopped working.
https://crm.ypi.com.ua/admin/shop/workflowstatus/826/action/new/
07.04.2025, 15:56
Maksym Vadimovich Tyndyk
OneBox production wrote:
Good afternoon
Do you need more information?
08.04.2025, 14:09
it would not be bad to have an example of a test process where an error occurs
08.04.2025, 14:36
How do you properly reset it?
08.04.2025, 14:39
link to this topic
08.04.2025, 15:36
Business process - https://crm.ypi.com.ua/app/workflow/47/constructor/
At the Focus Tariff stage, the Focus Tariff subprocess must be created - https://crm.ypi.com.ua/app/workflow/31/constructor/
At the Register starter package stage, a Register starter package subprocess should be created - https://crm.ypi.com.ua/app/workflow/25/constructor/
Everything worked before, no one made any changes and they stopped working on their own
08.04.2025, 16:30
Can you now switch a specific process to the specified stage and check the created subprocess?
Because I'm trying here https://crm.ypi.com.ua/220020/ through a test procedure on click - everything created https://crm.ypi.com.ua/220028/ , so I'm not sure that there is a problem at the moment
08.04.2025, 16:54
everything is working now. Thank you
Why might it not work?
several processes that did not work
https://crm.ypi.com.ua/220003/
https://crm.ypi.com.ua/219998/
08.04.2025, 17:31
maybe there was a mistake that has already been fixed
08.04.2025, 17:42
