How to fix: [name_first] variable is not being substituted correctly
Maybe because the author of the comment is the user who is switching stages?
If you need to specify that the process client be used for variables in the specified action - you can implement the settings in 1 hour
21.03.2025, 11:03
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
Maksym Vadimovich Tyndyk
Mmmmm
my opinion is that a variable in any action should work according to the same logic
It turns out I'm wrong and this is a separate piece of work.
thank you sincerely
21.03.2025, 11:27
Legeza Vyacheslav
How many people - so many opinions
we often form our opinions based on our needs - and if such moments are corrected as errors - then tomorrow another client will appear, whose action is not configured for the client of the process - and will demand to return to the way it was - and who is right then?)
the action specifically specifies who will be the author of the comment - and it is taken to form variables
21.03.2025, 11:30
ФОП Легеза В.В.
Legeza Vyacheslav
looks like a justification for the incomplete logic of using variables according to the same algorithm for all actions
I make mistakes too and unfortunately I don't always admit my mistakes, although I try to do so.
but this is also a position
Thank you very much for the detailed comment.
21.03.2025, 11:45
ФОП Легеза В.В.
Tried to use this setting in action
According to the logic I just heard, it seems like the variable should be used correctly.
But No, it didn't work.
Unfortunately, nothing has changed, although the author of the comment seems to be the Client.
21.03.2025, 13:24
