Urgent, the action "Add contacts to the Process Contacts tab" has stopped working again
The "Add contacts to the Process Contacts tab" action has stopped working again.
This bug has been fixed more than once, but it keeps popping up again and again.
Here are the topics that have already been fixed
https://1b.app/ua/forum/business-processes-and-automation/18881-perestala-pratsy...
https://1b.app/ua/forum/manage-contacts-and-database-of-clients-and-leads/18898-...
https://1b.app/ru/forum/business-processes/15425-ne-srabativaet-deystvie-dodati-...
The symptoms are all the same:
I specially recreated everything on a test BP.
https://dai-spisat.1box.link/13167/
At the "add contact to process contacts" stage, set the action and specified the settings
added a client to the process and assigned him the value of an additional field, here is the link to the client https://dai-spisat.1box.link/app/contact/3132/
created a second contact for the test and assigned it the same value of the additional field https://dai-spisat.1box.link/app/contact/848/
But when you move to a stage, the action doesn't work.
Moreover, if I check the "Clear contact list before executing action" box in the action settings, it also does not work and does not delete contacts, which may indicate that the action is not launched at all.
I ask you to correct the error very urgently, as this is very important.
All automation is tied to this action, without it nothing works.
Please check the correctness of the action now.
21.02.2025, 15:24
Maksym Vadimovich Tyndyk
OneBox production wrote:
It works. Thank you for your promptness.
21.02.2025, 15:27
