Bulk delete priorities
Good afternoon
A question about priorities
I'll show you with an example
https://ukroptmarket.1box.link/app/workflowtype-first-type/, when you right-click on the process number, this window appears https://prnt.sc/a49c4cTjTeFr , here I can remove the priority altogether.
But if you select several tasks and try to delete the priority, then there is no such functionality in the "edit window" https://prnt.sc/JHJWdVY2_5Ah
Is it possible to add such functionality to the editing window?
Why is it necessary to delete it and not reduce it to a minimum?
09.09.2024, 14:46
