Migration of data/business processes
Is it possible to migrate business process data from one box to another? All fields should be transferred and, if possible, the history with comments. That is, everything on the screen
it is better to transfer the database from one box to another if you are the owner of both
because it needs both processes, and contacts, and comments, and additional fields
Do you currently have an integrator (implementation)?
04.09.2024, 10:36
Tindik Maxim Vadimovich
OneBox production wrote:
Roman wrote:
It is necessary that all fields and, if possible, the history with comments be transferred.
It is better to move the database from one box to another if you are the owner of both
because it is necessary and processes, and contacts, and comments, and additional fields
Do you have an integrator (implementation) at the moment?
Contacts and additional fields were transferred without problems, only processes remained, because the process import application does not work or is not designed to import new fields, but only to update.
06.09.2024, 11:08
