How to take into account the presence of a discount when calculating bonuses
There is the following need:
- it is necessary to calculate bonuses for orders;
- when there is a discount in hryvnias or as a percentage, bonuses are NOT calculated
There is a conflict in how sequential procedures work
See what happens in the video
https://youtu.be/cuN9r880-UU
Perhaps someone has solved a similar problem and has an effective solution.
Unfortunately, I've spent a lot of time on various combinations of triggering conditions, but every time I run into one condition affecting the other, it doesn't work the way I want it to.
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
Phew, finally figured it out and did it.
Now everything works.
Watch the video, please
https://youtu.be/aKYnJPtQcrk
How do you like this decision?
Comment if you are interested in getting the same opportunity.
Or just pass if you don't need it at all, because you don't give out bonuses.
13.06.2024, 19:03
I really like it when they find the solution on their own :)
27.06.2024, 14:58
close the firebox
03.07.2024, 10:22
