Good afternoon, previously you did this modification https://kiyservice.1b.app/app/automatization/hour/edit/ https://prnt.sc/ADcFN4W6roWC
Is it possible to evaluate the rework so that you can select warehouses and thus create task data that is available only in this warehouse
Yes, can you create a link via mono? Let me clarify one more point it is necessary to make it possible to select warehouses using a multi-list since there will be several such actions and 2-3 warehouses will be selected in each
Good afternoon. The revision has been uploaded. Setting name: Select warehouses. If warehouses are selected, only products that are available in the selected warehouses are taken into account
