Needs improvement in action Receipt the contents of the process to the warehouse
You need the option "Do not reserve products for related processes if the related process is closed or the products in it have already been shipped."
For example: if a customer order has already been shipped or is canceled and closed, then no goods should be reserved in it.
Care Department
OneBox production wrote:
Good afternoon. 1 hour
Thank you, I'm waiting for the invoice!
22.05.2024, 10:23
Good afternoon. Two settings appeared at the end of the action, check if everything is as you need.
27.05.2024, 14:47
Care Department
Yes, it works correctly, thanks!
28.05.2024, 14:58
