Sum of two fields
And if you need to perform a function. Let's say there are two additional fields for the digital process. And in the third field of the process you need to write down their sum. How to do it? Not for contact but for process.
At each stage there is a stage price field, which, when moving to the next stage, is updated and summed up in the Cost field
Using the action at the “Calculate and write a value in an additional field” stage, you can write a value in some process field based on a formula. Then you somehow need to copy this field either to the delivery cost or distribute the amount to the products - then the cost of the order will change.
05.04.2024, 15:12
