Unfortunately, it is not possible to make smaller sizes than the declared ones; alternatively, you can use the buttons in the lower right corner for convenient business process setup
Maria, thank you for your attention to the topic! The situation is as follows: Previously (a month ago), the minimum block size was 212 x 93. Now the new minimum size is 246 x 128. This is clearly visible in the 28 second video, apparently you didn’t watch it. If such changes were made, you just had to say - the minimum sizes were revised, now it will be like this. So is this a “bug” or a change in the system?
Hello. No changes have been made to this block since 2017.
the minimum size for a block is 122 * 54
[file]21800[/file]
[file]21800[/file]
[file]21800[/file]
Hello Dmitry. I entered the box from a laptop - the stage size settings can be adjusted to minimum values. I log in from the main device - it does not allow me to set the minimum stage size. I reset the cache on OneBox - it didn't help. I logged in through incognito - it didn’t help. Similarly through two other browsers. This is of course not your concern, but perhaps you have encountered this?
Hello Dmitry.
Laptop with connected 4K monitor. Previously, everything worked as expected, but at some point it stopped. I don’t remember exactly, but approximately a month ago. Could this have something to do with the resolution and the minimum size as a % of the screen?
Nikolay wrote: Laptop with connected 4K monitor. Previously, everything worked as expected, but at some point it stopped. I don’t remember exactly, but approximately a month ago. Could this have something to do with the resolution and the minimum size as a % of the screen?
4k monitor without browser scaling? I think this is the issue
Nikolay wrote: Dmitry, thank you! When scaling to 200% everything works correctly. At 175% or less it no longer works.
This is a common glitch in most devices; when scaling, the actual dimensions disappear due to upscale or downscale graphics
Nikolay wrote:
Dmitry, thank you!
