When opening or saving a task, 2-3 minutes pass before this action takes place.
In this case, the loading of other pages stops or gives an error.
At the same time, opening the download or saving documents in another subsection works without problems.
There is also a problem with logging into CRM.
All users are unable to log in.
The page simply does not load.
When switching to a VPN, you can log in.
After a while it resumes normal operation without VPN.
When opening or saving a task, 2-3 minutes pass before this action takes place. In this case, the loading of other pages stops or gives an error. At the same time, opening the download or saving documents in another subsection works without problems. There is also a problem with logging into CRM. All users are unable to log in. The page simply does not load. When switching to a VPN, you can log in. After a while it resumes normal operation without VPN.
