The search field was on the same line with the process step selection.
[file]21604[/file]
[file]21605[/file]
The search does not work either when you type or when you click the Search button.
[file]21604[/file]
[file]21605[/file]
For example, in the Automation works section
[file]21604[/file]
[file]21605[/file]
[file]21604[/file]
[file]21605[/file]
[file]21604[/file]
[file]21605[/file]
