The setting in the action "Send an SMS N minutes before the scheduled date", namely "Send a message only 1 time", does not work.
[file]21402[/file]
[file]21403[/file]
Even if the tick is on, it sends an SMS every minute, why so?
[file]21402[/file]
[file]21403[/file]
https://autocapriz.1b.app/admin/shop/workflowstatus/33/action/new/ - the stage at which the action is set
[file]21402[/file]
[file]21403[/file]
https://autocapriz.1b.app/app/sms-turbosms/ - check turbo sms
[file]21402[/file]
[file]21403[/file]
[file]21402[/file]
[file]21403[/file]
[file]21402[/file]
[file]21403[/file]
The action works correctly One notification is sent only once. The text of your notification changes, so it is considered different and sent again. Using the example of number xxxx2592, there were 2 messages with different texts xxxx Date: 2023-10-16 10:10:00 tel. xxxx xxxx Date: 2023-10-16 10:00:00 tel. xxxx those. Between 2 alarms, someone changed the date in the variable and therefore sent another SMS.
in fact, if you look at records 312-320, you can see that the messages did not change, as did the numbers, but were sent every minute.
got around it so far with statuses, but setting in action doesn't work :p
[file]21404[/file]
[file]21405[/file]
[file]21404[/file]
[file]21405[/file]
[file]21404[/file]
[file]21405[/file]
[file]21404[/file]
[file]21405[/file]
