Here is an example problem https://iivancom.1b.app/15/
[file]21070[/file]
In the process, a procedure is configured in which I use the action: Calculate and record the value in an additional field, if the conditions are met
[file]21070[/file]
According to how the action is configured, it should write the value as on the screen.
[file]21070[/file]
However, when the action executes, it writes data with an error
[file]21070[/file]
To make it easier to understand the bug I'm observing, I made a video
[file]21070[/file]
https://youtu.be/IPSi61yJ6v4
[file]21070[/file]
Please correct this error
[file]21070[/file]
[file]21070[/file]
Good evening Most likely, either there is a copying action that works without conditions, or there is no checkmark in the existing action so that the calculation is for each product separately
Good evening
Maria OneBox production wrote: Good evening Most likely, either there is a copying action that works without conditions, or there is no checkmark in the existing action so that the calculation is for each product separately
Thanks, it helped
Maria
Good evening
Thanks, it helped
[file]21074[/file]
Roman Sergeevich Yurchenko wrote:
[file]21074[/file]
Greeting!
[file]21074[/file]
Try using this https://prnt.sc/7doUGEuwJwr7
[file]21074[/file]
[file]21074[/file]
Roma, thank you very much, it was this tick that worked
[file]21074[/file]
[Maria #8] wrote the first answer
[file]21074[/file]
[file]21074[/file]
Maybe it makes sense to adjust the name of the checkmark so that it is more clear what it affects? For example, like this: Check this box when conditions are imposed on additional fields of the products of the process fields, so that the calculation based on the imposed conditions is carried out for each row separately,
Maria
Good evening
