An error occurred in the operation of the action Check the availability of products in the warehouse
Here is the task https://invafishki.1b.app/296056/
We sell 20 units of the product
1 unit is available
We use the action Check the availability of products in the warehouse to switch the task to Procurement, since there are not enough products.
At the same time, it gives an error, as on the screen
It's very likely that the box is seeing a partial balance in stock and is therefore trying to switch to the In Stock status
Although according to logic, you should switch to Purchase, because the product is partially available, and the one that is not, you need to buy additionally.
Please tell me how to fix it so that the task switches to the status, then we create a task for purchasing from the supplier.
The action checks the FULL availability of the product in the warehouse and not just one piece. Accordingly, it shows you an error that the goods are not in the required quantity in the warehouse. There is absolutely no point in checking if there is 1 out of 20 in stock, since in any case you need to buy from the supplier.
17.08.2023, 14:55
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
Department of Care
OneBox production wrote:
The action checks the COMPLETE presence of the product in the warehouse, not just one piece. Correspondingly, it shows you an error that the product is not available in the warehouse. There is absolutely no point in checking whether there is 1 piece out of 20 in stock, since in any case you need to buy more from the supplier.
Yes
and if there is not a full amount, then it should switch to the stage where we purchase an insufficient amount
seems to have found the cause of the error I'm seeing
The client independently added the availability check action at the stage of Purchasing, hence the conflict
17.08.2023, 17:16
