Can you please tell me by what action the field "Customer's full name (order.order_clientname)" can be copied to the Additional field?
Can you please tell me by what action the field "Customer's full name (order.order_clientname)" can be copied to the Additional field? Or the second option is how to copy the same field from the parent process "Order of the Buyer" to the subprocess "Order to the supplier"
Congratulations!
You can copy this field using the "Copy process fields" action
Here it is: https://tppr.me/6SyLt
18.05.2023, 11:22
If you need to copy from the parent process, you can also use this action with the following setting:
https://tppr.me/nZhWl
That is, the action will take the PIB of the process client from the parent process and write it in an additional field in the current process
18.05.2023, 11:24
