When creating an action to check fields, the fields in the action and the fields in the Business process are different. They do not match. How to configure them? I marked on the screen which fields I was looking for
[file]20202[/file]
[file]20203[/file]
[file]20202[/file]
[file]20203[/file]
[file]20202[/file]
[file]20203[/file]
Good day! In this action, there are no specified fields, I mean the name of the process and the e-mail address of the client of the process, so you cannot mark them as mandatory. And so, in general, you can always find fields by the identifier, it matches, for example, in the interface, the user.namelast field in the action can be found similarly by the identifier "user.namelast". The simplest solution, in my opinion, would be to create two additional process fields, copy the values of the process name and the process client's email into them, and then check the completion with the action "Check for completion of the required fields"
