BAG I cannot add a contact in the additional field of BP
Sergey, good day.
in order to be able to select or copy a contact into an additional field - it must be of the Contact Directory type
16.03.2023, 16:34
Ihor Susiak
The integrator wrote:
Sergey, good day.
I understand that.
Everything worked for me.
Add. I checked the field, it hasn't changed, and there is "Contact Directory".
16.03.2023, 16:37
I have 2 tabs in the interface.
Basically, I can't do anything to the tab (the field does not have a ban on editing).
In the second tab, for some reason I can change the add. field
16.03.2023, 16:51
Do not put the same field in different places of the same process. Box considers this a take and may overwrite or ban the recording.
16.03.2023, 16:53
Ihor Susiak
I already understood that.
I delete this field in the second tab, but I still can't change it in the main.
16.03.2023, 16:55
without access to boxing it's hard to say.
try adding the field on another business process, for example in a Simple task
16.03.2023, 19:05
Ihor Susiak
In this case, everything is ok. Everything works on other processes.
This field does not work iminally on the main tab of the process.
16.03.2023, 19:07
So the problem is only there. Maybe you put 2 identical fields on the main process tab?
16.03.2023, 19:46
Ihor Susiak
No
There are no duplicates, that's for sure.
Although when I put a duplicate of this field in the additional tab, everything is ok and I can change the field.
At the same time, I can't talk to you
16.03.2023, 19:49
Ihor Susiak
Thanks for the help. Found a duplicate.
17.03.2023, 07:32
