Here is an order
[file]19366[/file]
[file]19367[/file]
[file]19368[/file]
https://sara.1box.link/34790/
[file]19366[/file]
[file]19367[/file]
[file]19368[/file]
He moved to the stage
[file]19366[/file]
[file]19367[/file]
[file]19368[/file]
[file]19366[/file]
[file]19367[/file]
[file]19368[/file]
At the same time, at the Liqpay stage, the transition is prohibited if the field = 1
[file]19366[/file]
[file]19367[/file]
[file]19368[/file]
[file]19366[/file]
[file]19367[/file]
[file]19368[/file]
And this field is filled just at the stage "Paid"
[file]19366[/file]
[file]19367[/file]
[file]19368[/file]
[file]19366[/file]
[file]19367[/file]
[file]19368[/file]
That is, at the time of the transition, this field was = 1, which should not have allowed the system to switch to this stage
[file]19366[/file]
[file]19367[/file]
[file]19368[/file]
The history shows that the field was filled AFTER the transition to the status and not before (the higher the entry in the history of changes, the later the event occurred). And the transition to the status of the likpay was clearly from some action once every X (minute, hour) and filling the field manually or after a manual transition.
[file]19393[/file]
[file]19394[/file]
[file]19393[/file]
[file]19394[/file]
[file]19393[/file]
[file]19394[/file]
