Assess the possibility of improvement
Good afternoon
There is a process in which the goods (not credited in the warehouse) consist of several materials. When shipped from the warehouse, this product is broken down into components and the components are deducted from the warehouse.
On one of the statuses, goods or materials are reserved. If the item is not in stock, a process to the supplier is created.
But it is necessary to buy not the goods of the passport, but its components. Therefore, in the BP, the supplier is dismantled.
To what extent is it possible to refine the following functionality:
1. When posting from the process to the Supplier of passport materials, reserve these materials for the product passport in the process?
An example of how this happens with a product without a passport https://arp.1b.app/3717/ - the product is reserved
An example if in the process a product with a passport https://arp.1b.app/3716/ - the materials were not reserved.
What action can be modified for such functionality? As much as possible? How many hours?
Really looking forward to the answer!
Original question is available on version: ru Інтегратор CRM+ERP. Компания Olmonic
Morozova Olesya
you need to transfer not goods but materials to the supplier process at once, then everything will work
15.02.2023, 21:12
Olmonic Olmonic
Інтегратор OneBox
.dev
OneBox production wrote:
Morozova Olesya
Materials are transferred to the process to the Supplier. But when posting these materials, they are not reserved for the client's process.
If the order contains goods without a passport, everything is automatically reserved.
If the posting of passport materials - there is no reserve of goods with a passport in the order
16.02.2023, 08:16
Інтегратор CRM+ERP. Компания Olmonic Original comment available on version: ru
You should always reserve if there is a relationship with a sales order item from a supplier item. Give an example of a supplier order and a customer order, most likely there is no connection there.
16.02.2023, 11:41
Olmonic Olmonic
Інтегратор OneBox
Customer order https://arp.1b.app/3716/
Material supplier process https://arp.1b.app/4301/
For example, in this process https://arp.1b.app/3717/ the goods without a passport and upon receipt from the process to the supplier are automatically reserved goods at the stage.
But where the goods consist of a passport, the materials are credited, but the reserve does not work, as in the case of process 3717.
16.02.2023, 12:33
Olmonic Olmonic
Інтегратор OneBox
Morozova Olesya
Those. To do this, click on the Reserve button.
The problem is how to do it automatically. Without user intervention
16.02.2023, 12:38
Olmonic Olmonic
Інтегратор OneBox
The question is relevant
14.03.2023, 08:29
Olmonic Olmonic
Інтегратор OneBox
What action can be modified for the functionality described in the topic? As much as possible? How many hours?
Really looking forward to the answer :)
.dev
23.03.2023, 10:26
