When we use passports, the reverse action does not work: Replace the materials with the product from which it is composed
Here: balistyka,1b,app
Example problem: balistyka,1b,app/140/
The action on the deployment of the passport works and everything is OK.
In this case, the reverse action does not work: Replace the materials with the product from which it is composed
Screen 1283
Looks like a bug, as I checked in another box, everything works fine.
Here is the video: https://youtu.be/1kM37VQQKMQ
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
A paid task was set on the same question
https://1b.app/ua/forum/managing-the-base-of-goods-and-services/16497-ne-spratso... /
this task can be closed as not relevant
08.02.2023, 11:23
topic closed
08.02.2023, 11:36
«Один юрист із портфелем у руках награбує більше, ніж банда автоматників» Original comment available on version: ru
