Balance in warehouses in the "products by table" block
For some reason, it doesn't show the balance correctly if you select an employee
I have included so that employees can be warehouses.
I can't understand anything from your question
and what should be?
24.01.2023, 23:22
Ustimenko Igor
and what should be?
Must write the remainder of 1 pc
See that this is the same product, but different compositions are indicated.
25.01.2023, 09:58
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
Sergey, see what the problem is, from my point of view.
You don't actually have any employee balances. This can be seen when we go to the warehouses and look at the balances of the warehouses.
Briefly, as I suggest to always do:
- posting ONLY through a task in the posting business process;
- move ONLY through a task in the Move business process.
In this way, you will always see, even when you do not start working yourself:
- who;
- what exactly;
- when did
And it will be much easier to track not only actions, but also the consequences of such actions.
Unfortunately, it is difficult for me to help you with anything right now, since I am categorically in favor of using business processes to perform certain tasks.
That is, when you create business processes for posting and movement and start working through them, you will start to see what is in the warehouse.
Please let me know if I can set it up to close your task.
Tariffs for turnkey business processes here https://icoloronebox.org.ua/product-category/allproducts/process-templates/
28.01.2023, 09:52
