Add a field to the 'Copy process product fields' action
Igor, good day
please explain in more detail what is important to you - do you have to write down a different value for each product based on the formula every time, or calculate VAT in the process depending on something, or just load the value once?
* for import/export there is an app https://1b.app/ua/app/exchange-product/
for internal calculations, approximate actions: https://take.ms/oqtmc
15.12.2022, 18:01
Dydyk Ihor
ПП
Ihor Susiak
The integrator wrote:
Igor, good day
When importing goods (purchased from foreign companies) upon customs clearance, they may have a VAT of 7% or 20%.
Therefore, in the order, the list of goods may contain goods with both 7% and 20%.
Also, the same product for different purchases can similarly have either 7% or 20%.
Therefore, as an option: the possibility to issue a VAT rate for all (selected) goods in the process.
PS At the moment I think to solve this issue with two actions:
1. 'Calculate and record the value in the additional field'.
2. 'Copy process product fields', if there was a VAT (%) field in the list (producttaxvalue).
16.12.2022, 08:49
as of today, the box has implemented one field "Amount of VAT on the product:" in the product card. it can be filled manually or by bulk actions.
In the table of products, you can display this field: "VAT (%) (producttaxvalue)", but it is not available for editing.
I think that the simplest option is to make a half of the product of the process and multiply the price by the VAT rate from it. Your actions will probably be suitable for this.
If you need something more complicated, to connect with legal entities - perhaps write separately for developers, how you would like to implement.
16.12.2022, 16:50
Dydyk Ihor
ПП
Ihor Susiak
Actually, this is what I want to achieve, but it is necessary that there should be a field "VAT (%) (producttaxvalue)" in the list, since the price with VAT when saving the process is recalculated according to the VAT rate.
And for this, it is enough to provide access to the field "VAT (%) (producttaxvalue)" with the possibility of editing it.
20.12.2022, 09:45
