There is a task Procedures on a clique to show only to certain roles.
Some of the buttons are seen by some employees, some by others.
Now all employees see all the buttons (if they are displayed), which overloads the window interface.
Good afternoon. There is a task Procedures on a clique to show only to certain roles. Some of the buttons are seen by some employees, some by others. Now all employees see all the buttons (if they are displayed), which overloads the window interface.
Did as recommended - does not work. And even if it worked, the method recommended by you is inconvenient. Is it possible to implement what I suggested?
Mitrofanov Vitaly wrote: Did as recommended - does not work. And even if it worked, the method recommended by you is inconvenient. Is it possible to implement what I suggested?
most likely you set up the Marina option incorrectly, give a link - I'll tell you what's wrong. Your option can be implemented through revision, estimate approximately 3 hours
Mitrofanov Vitaly wrote: A little more, and a month will pass as we wait for an answer! Loyalty is on the rise!
Hmm, where did you see the rules of the answer or the deadlines on the forum? If you have a TP from one of the partners from them and demand deadlines, but not on the forum.
