Есть запрос на разработку нового функционала? Создайте топик на форуме и партнер-разработчик с радостью предоставит ответ по возможности разработки и оценке.
Создать топик на форуме
Let me explain with an example:
We create processes from different processes, they are not interconnected, in each of these processes in the add. process field is written "Code". For example, we created 10 processes, they have the same code.
Next, we create a separate process (there will be a code in it) in which you need to add products from processes that have additional. field is written this code, which is in the same process.
We use the action Add products from one process to another with the setting "From a process in the specified business process and status to the current process"
But there is no way to search for processes according to this logic, it searches by client, bp, status.
Need an evaluation
Let me explain with an example: We create processes from different processes, they are not interconnected, in each of these processes in the add. process field is written "Code". For example, we created 10 processes, they have the same code. Next, we create a separate process (there will be a code in it) in which you need to add products from processes that have additional. field is written this code, which is in the same process. We use the action Add products from one process to another with the setting "From a process in the specified business process and status to the current process" But there is no way to search for processes according to this logic, it searches by client, bp, status. Need an evaluation
Korop Vladislav Pavlovich QubeSoft wrote: But there is no way to search for processes according to this logic, it searches by client, bp, status.
If you need to add a search setting there in addition to the BP / status + comparison of additional fields - 2 hours
