the action Deny transition depending on the fields does not see the field filled with the file type
В последней версии системы мы максимально проработали сложные для новичков моменты и стало намного проще настраивать и работать в системе!
Рекомендуем установить последнюю версию или обновиться! Установить последнюю версию системы
Good afternoon. The action Prohibit the transition depending on the fields http://joxi.ru/1A5YMZpszM493A is set, it is disabled if the field with the file type is empty (Kp file field) Configured on the test procedure https://crm.ohrana.ua/admin/shop/workflow/ 16/procedure/792/?status=0 and the problem is that the prohibition does not work out and skips the transition further, that is, this action does not see that the field is empty. At the same time, after the ban, a viber message is sent with this file, and it is important that when you click on the procedure, the process simply freezes for eternity, but the Empty message leaves the client.
Process for the test https://crm.ohrana.ua/admin/customorder/type/2095469/edit/, you can click on the specified procedure (message test)
Please check
Specify how the file was previously removed from the process?
22.10.2021, 17:15
manually through the button to delete the contents of the field
22.10.2021, 17:28
OneBox Corp - Інтегратор
if the file is deleted, then the value is written in the field deleted
To make it work, add an additional check, but with the condition that the field is "deleted", something like this
Although if you fix it, it will be better
22.10.2021, 17:50
Fixed for future deletions to record blank.
25.10.2021, 15:39
great, thanks check it out
25.10.2021, 15:41
OneBox production
works, thanks, close
26.10.2021, 09:21
