Good afternoon
Filtering the remaining goods by article number https://prnt.sc/jsXzW9oSlN6e
https://egorini.1b.app/app/storage/tab/balance/?storagenameid%5B%5D=51&articul=564&ok=1
shows 34 total balance
if you calculate in the table below, you get 29 https://prnt.sc/RBj0RZ5lNBi0
what could be the problem?
https://egorini.1b.app/app/storage/tab/balance/?storagenameid%5B%5D=51&productid=1360&productid=1361&productid=1360%2C1361&ok=1 this is how the data matches. You probably have a hidden product with article 564 that is displayed in the general balances but cannot be shown in the list below.
Understood shows deleted products in the balance tell me, is it possible not to show deleted products in the balance by default? do you have to click the checkbox? https://prnt.sc/y_eq4HDQ3ozt
Understood
just write off the deleted products or save the necessary checkbox in the filter (filter as you need to show with a checkbox and then at the bottom of the filter panel there is a filter save)
Greetings! I understand your problem and it seems that the issue may be the different data sources that the system uses to calculate the balances. Check that all data is up to date and in sync. Sometimes such discrepancies arise due to incorrect filtering settings or a delay in updating information on the server. It might also be worth looking at your inventory settings to make sure all balances are accounted for correctly. Alternatively, you can try to manually compare the balances for each article and see where exactly the difference occurs. Have you already contacted technical support about this issue? Perhaps they can give a more precise explanation.
