We need total lines for all columns with numerical values in Re-Accounting and in Saved Re-Accounting Records.
[file]22367[/file]
[file]22368[/file]
[file]22369[/file]
The number in the total rows should change immediately after editing the table without refreshing the page:
[file]22367[/file]
[file]22368[/file]
[file]22369[/file]
- after scanning the barcode of the product,
[file]22367[/file]
[file]22368[/file]
[file]22369[/file]
- after pressing the Save (or Enter) button when manually editing the quantity field,
[file]22367[/file]
[file]22368[/file]
[file]22369[/file]
- and other ways to add/remove products
[file]22367[/file]
[file]22368[/file]
[file]22369[/file]
[file]22367[/file]
[file]22368[/file]
[file]22369[/file]
[file]22367[/file]
[file]22368[/file]
[file]22369[/file]
[file]22367[/file]
[file]22368[/file]
[file]22369[/file]
Rodion wrote: We need total lines for all columns with numerical values in Re-Accounting and in Saved Re-Accounting Records.
if displayed when loading the page (without dynamic changes) - then this is 4 hours for re-accounting and for saved records
Rodion wrote: The number in the total rows should change immediately after editing the table without refreshing the page:
but if with dynamic recalculation, then this is +4 hours on top of the estimate above
Rodion wrote: Let's then do it only in Saved Entries, how much will it be?
Yes, it doesn’t change the essence of the matter - in fact, the data output is the same in both places - you just need to implement it all in one place, and screw it into another that is, I would say this - 6 hours in one place, and then 2 hours in another, screw it in the same way
Tindik Maxim Vadimovich OneBox production wrote: that is, I would say this - 6 hours in one place, and then 2 hours in another, screw it in the same way
This is with dynamic recalculation, right? The priority is the Total rows in Saved records, and there the page itself is reloaded using the Edit record button. Therefore, dynamic recalculation is not needed. This will be 2 hours, if only in one place and without dynamics?
Okay, come on, is it possible to also make the error window red in re-accounting if the barcode is not found? Otherwise, it is almost no different from the notification of the successful addition of a product.
[file]22401[/file]
[file]22402[/file]
[file]22401[/file]
[file]22402[/file]
[file]22401[/file]
[file]22402[/file]
Rodion wrote: Okay, come on, is it possible to simultaneously make the error window red in re-accounting if the barcode is not found?
As part of this revision - no. I will arrange for you to receive an invoice.
