Good afternoon
Interested in questions about changing the balance of warehouses
1. how the last two amounts differ https://prnt.sc/xYzDTDOeRckZ
2. inconsistency in amounts at the end of the month and at the beginning
take two months
April https://kiyservice.1b.app/app/storage/tab/monitor/?datefrom=2023-04-01&datet...
pay attention to the field "balance amount" total value
May https://kiyservice.1b.app/app/storage/tab/monitor/?datefrom=2023-05-01&datet...
pay attention to the field "initial amount" total value
question: why does the amount from the end of the month not go to the beginning of the month?
Care Department
OneBox production wrote:
the links are cut, try throwing them in a comment or in a txt file
April https://kiyservice.1b.app/app/storage/tab/monitor/?datefrom=2023-04-01&dateto=2023-04-30&storagenameid%5B%5D=10&storagenameid%5B%5D=11&storagenameid%5B%5D=12&storagenameid%5B%5D=16&storagenameid %. %D1%8C
May https://kiyservice.1b.app/app/storage/tab/monitor/?datefrom=2023-05-01&dateto=2023-05-31&storagenameid%5B%5D=10&storagenameid%5B%5D=11&storagenameid%5B%5D=12&storagenameid%5B%5D=16&storagenameid%5B %5D=15&storagenameid%5B%5D=25&storagenameid%5B%5D=23&storagenameid%5B%5D=22&showalltotal=1&ok=%D0%A4%D0%B8%D0%BB%D1%8C%D1%82%D1%80%D0%BE%D0%B2%D0%B0%D1%82%D1 %8C
The specified report shows exactly the movements in the warehouse, i.e. only those warehouse balances that were sold, accounted for, moved, etc. through the warehouse during this period. Those. if there is some product "table", then it and its batch will be included in the filtration 2023-04-01-2023-04-30 only if the batch of this product was "moved" in the warehouse on the specified dates. If no one touched him, he will not get into the display.
accordingly, the amounts at the beginning of the period and the end are taken only for the parties that moved in this month, i.e. the set of batches of products for the periods 2023-04-01-2023-04-30 and 2023-05-01-2023-05-30 will be different, respectively, and the amounts are different
Care Department OneBox production wrote: accordingly, the amounts at the beginning of the period and the end are taken only for the parties that moved in this month, i.e. the set of batches of products for the periods 2023-04-01-2023-04-30 and 2023-05-01-2023-05-30 will be different, respectively, and the amounts are different
thanks for the answer And how to get the balances for all batches for a date? i.e. not at the current moment, is it clear where to get it, but on a date in the past?
Care Department
https://kiyservice.1b.app/app/storage/tab/balance/?dbalFrom=2023-07-01+00%3A00&dbalTo=2023-07-01+00%3A00&ok=1
here is an example of a filtered one. On the right you can see the amounts "Maximum sale value", you have a period of 1 day, respectively, this is the amount of products for that day that were in stock
Thank you passed the information to the accountant will check tomorrow send card number
Care Department
Thank you
will check tomorrow
send card number
If you want to leave a donation, please do it on the forum under any of my comments, it will go to my account and I can then convert it into a cash equivalent if necessary. Thank you.
