There is an order to the supplier process https://senseeducation.1b.app/app/workflowtype-sklad/ it has a warehouse field for posting for posting to a specific warehouse, and a cell for posting to a cell. If in warehouses you name a cell with a digital value (1,2,3), then you can specify this number in the "cell" field and the product will be credited to this cell. But if the value is not digital (as in the screenshot) [file]18017[/file] then this value cannot be entered in the cell field.
Here, in general, the question is, how is it correct to post products to different warehouses and cells within the same process?
[file]18018[/file]
Thank you for your time!
There is an order to the supplier process https://senseeducation.1b.app/app/workflowtype-sklad/ it has a warehouse field for posting for posting to a specific warehouse, and a cell for posting to a cell. If in warehouses you name a cell with a digital value (1,2,3), then you can specify this number in the "cell" field and the product will be credited to this cell. But if the value is not digital (as in the screenshot) then this value cannot be entered in the cell field. Here, in general, the question is, how is it correct to post products to different warehouses and cells within the same process?
Valeria Consulting company "Sales Bureau" wrote: There is an order to the supplier process https://senseeducation.1b.app/app/workflowtype-sklad/ it has a warehouse field for posting for posting to a specific warehouse, and a cell for posting to a cell. If in warehouses you name a cell with a digital value (1,2,3), then you can specify this number in the "cell" field and the product will be credited to this cell. But if the value is not digital (as in the screenshot) then this value cannot be entered in the cell field. Here, in general, the question is, how is it correct to post products to different warehouses and cells within the same process?
you just have to start writing the cell name and you will be presented with a choice of available cells
Valeria
[file]18018[/file]
