You can install OneBox using the link https://crm-onebox.com/ru/?ref=21
CRM for automatic adjustment of orders in the warehouse from SheBo
The application will be an addition to your customer order PSU, namely, it will be responsible for transmitting order data to your storekeeper in Telegram or Viber.
How it works:
- The system collects the necessary data according to the order for the storekeeper;
- Further, with the help of automation, the data will be transferred through the bot to your employee in the warehouse.
- It is also possible to adjust the data transfer, you will be able to transfer all the necessary information on the products in the order, as well as individual data on the order. Your storekeeper will be able to ask questions about the order via messenger for a quick response.
The application can be changed, programmed and customized for your business. You can do it yourself according to our documentation or with the help of third-party companies or individual programmer
You can install OneBox using the link https://crm-onebox.com/ru/?ref=21 CRM for automatic adjustment of orders in the warehouse from SheBo The application will be an addition to your customer order PSU, namely, it will be responsible for transmitting order data to your storekeeper in Telegram or Viber. How it works: - The system collects the necessary data according to the order for the storekeeper; - Further, with the help of automation, the data will be transferred through the bot to your employee in the warehouse. - It is also possible to adjust the data transfer, you will be able to transfer all the necessary information on the products in the order, as well as individual data on the order. Your storekeeper will be able to ask questions about the order via messenger for a quick response. The application can be changed, programmed and customized for your business. You can do it yourself according to our documentation or with the help of third-party companies or individual programmer
Компанія SheBo спеціалізується на впровадженні CRM системи OneBox, продаж тарифних планів OneBox (хмара, коробка). У нашому портфоліо понад 100 успішно впроваджених проектів і більш 20 різних напрямків бізнесу. Унікальні технології впровадження проектів, були розроблені спільно з технічними фахівцям
For more detailed information, contact the following contacts:
+380663508850
+380937846074
u.bolotian@shebo.com.ua
a.sheyko@shebo.com.ua
y_bolotyan@ukr.net
http://shebo.com.ua
Here is a finished article that describes all the popular fulfillment operators. Choose what you are interested in https://crmmarket.com.ua/fulfliment-operatory/
on the site - nofollow - your attempts are useless
