Knowledge management training
Functionality of training in boxing.
At the moment, boxing has a handy knowledge base tool. Where in each article you can specify which role employees (https://crm.infosaver.ru/admin/role/195/) should read it. For mandatory (forced) familiarization of an employee with a record, there is a checkbox Standard mandatory for familiarization, this is convenient when you need to familiarize an existing employee, but if we assign a new employee to this role, then a bunch of records fall out, sometimes without any system because of which learning is poor.
What do I propose.
in the role card https://crm.infosaver.ru/admin/role/195/ create a separate training tab in which to display a list of records from the knowledge base (when adding a record from the knowledge base here, you need to automatically add that the employee of this position should read), In addition, you need the ability to change the display order (sequence) of articles for review.
This refinement will allow, when an employee is a
accepted - will be in the next releases (we cannot specify the exact date unfortunately
20.01.2021, 11:36
«Один юрист із портфелем у руках награбує більше, ніж банда автоматників» Original comment available on version: ru
