Problems after finalizing One Box
Good afternoon!
After the completion of the system by One Box employee Luts Bogdan Alexandrovich, we had serious problems with the system, namely constant freezes, ejection of employees from the system, as well as non-saving of the entered data.
A huge request to deal with this problem and return the system to working capacity !!!
Now it is not possible to work in the system normally!
:D
will there be more accurate data?) what and where is wrong
13.07.2021, 15:54
All over the system! When changes are made to tasks, data is not saved the first time, when access rights are changed, the same thing is not saved the first time. Freezes are present throughout the system
13.07.2021, 17:22
I think you either have a problem with the server or with the Internet
you can record a video
and it’s not clear where Lutz Bogdan has to do with it - if he’s not even a OneBox employee ...
13.07.2021, 17:55
