There is an action Universal import of products (xml/json) https://crm-access.kronas.com.ua/admin/auto/action/hour/edit/
It does not update products by cron. And the crowns in the check are also NOT OK.
Can you point out what the problem is?
You have 5 universal import actions hanging. If you look at them, then at the bottom of each of them there is information about how much was updated / added last time. Among these 5, only the third action in a row does not have such information, and if you expand it, they write in red what is wrong Which of the 5 actions in your opinion does not update products?
