I guess, I don’t work from the very wound http://box.7sorok.ua/
Prohannya encourage the robot. Launch into the database itself, but there is a white screen and nothing is heard. Partially, only one distribution was made with warehouses, where you can use the leftovers
[file]4464[/file]
I guess, I don’t work from the very wound http://box.7sorok.ua/ Prohannya encourage the robot. Launch into the database itself, but there is a white screen and nothing is heard. Partially, only one distribution was made with warehouses, where you can use the leftovers
Good afternoon. The server has run out of space. File System Size Used Dst Used % Mounted In /dev/sda1 76G 76G 0 100% / Needs to be cleaned. If we do this we have 1 hour.
Am I right in thinking that 76 GB is loaded? І naskіlki vystachit purges, did we take a month with a great supply? Well, clean up the mess, but if you want to understand, to stick to the skids, or to reverse, why is it so conspicuous. Once upon a time, yakіs uncommon dії knew, yakі scored a memory.
