Unloading processes from the LC
In the LC in the list of All processes there is an export option - https://prnt.sc/10cxsaw
When unloading, the Products field writes in one cell - https://prnt.sc/10cxu28
We need a solution: Write the product in each separate line. In this case, the value of common columns is combined - an example https://prnt.sc/10cxvo8
Can this be done?
What is the solution? What is the hourly assessment?
No, we will not do this in this export (because half of the TK cannot be done, at least by merging cells). Note that this is a process export where the entity is the process, not the product.
If it is vital for you to be able to export with further use somewhere, it is better to set up some kind of export automation.
05.03.2021, 15:27
Premium partner
The bottom line is that export is needed exactly in the LC and on orders, but it is more convenient to see the goods in it (Not everything in one line). Perhaps there is an option to simply provide another form of export to the XLS file? For example, according to the client template
07.03.2021, 17:10
I can only suggest doing it in such a way that there will be 1 line of data on the process + 1st product, and then the lines (without data on the process) will be data on the rest of the products (for example, 2 more lines). And the data for the next process will be from the 4th line, and so on.
At the same time, concatenation of cells of rows, etc. will not.
If this option is suitable, I am ready to implement it in the form of a setting in this block in 15 hours.
09.03.2021, 12:25
