Help solve the issue.
Given:
There is a main product for example Test, on the site we create several options for searching Test 1, Test 2. It is necessary that when ordering, for example, the product Test 2 in the box changes to the main Test.
Previously, such an opportunity was made through product analogues, but now analogues work both ways if they ordered the correct product Test and in the box it immediately changes to the opposite analogue for Test 1
How can I set up a variant of a one-sided analogue in boxing. Or perhaps there are other solutions.
Thanks a lot.
Good afternoon. Help solve the issue. Given: There is a main product for example Test, on the site we create several options for searching Test 1, Test 2. It is necessary that when ordering, for example, the product Test 2 in the box changes to the main Test. Previously, such an opportunity was made through product analogues, but now analogues work both ways if they ordered the correct product Test and in the box it immediately changes to the opposite analogue for Test 1 How can I set up a variant of a one-sided analogue in boxing. Or perhaps there are other solutions. Thanks a lot.
As far as I remember, when adding an analog to a product, this product becomes an analog to the one being added - but you can go to the list of analogs and note that this product is not an analog in the opposite direction (like the "Not an analog" checkbox). Thus, you can set analogues in "one way". Well, for replacement, there is an action at the stage of the process "Replace the product with its analogues"
