Incorrect balances for price list products that are filled in manually
Question of the following nature. Incorrect balances for goods in price lists that are filled in manually have become more frequent. It looks like this, the price list in Excel is uploaded to the box, let's say a technomaster and etc. examples 769181, 743702(technomaster), 767453 (etc) by the dates of the upload, it can be seen that the deadlines are outdated and the goods shone as they are in stock although they are not in the price list, the prices are updated on the box regularly 1-2 times a week, why these positions do not disappear from the balance as in stock if the price list is reloaded.
621820 another example
When setting such tasks - provide an example of a price list (preferably only with problematic downloadable positions) and indicate the sequence of your actions.
I recommend that you make a file for several positions, upload it, and in case of a problem, describe why and based on what settings you think that something should work differently.
15.01.2021, 17:24
We tell you step by step how to load the price list: using the example of Technomaster, namely, by product code 769181, he is also the Ventolux ICELAND Oven.
We load the price, make a selection and leave the positions only those that are available, the rest we delete. Loading price.
And on the example of the position, as we wrote above with the code 769181, we see, see pic 2.
We are looking for it in the price list that was uploaded "Ventolux ICELAND Oven" see fig. 3
We look at the binding of products, this position says that it is in stock" see Fig. 4
The same 743702."Washing machine Electrolux EW 6S426 WU"
We attach the price of the Technomaster.
Similar to 767453 etc, this is the Samsung RB30N4020B1/UA Refrigerator, it is not in the price list, but in the binding it is written in stock, see 5, we also attach the price file.
"I recommend that you make a file for several positions, upload it, and in case of a problem, describe why and based on what settings you think that something should work differently."
Your recommendation probably brings an even greater problem and cost of work in the future "Why!? As we can see, the position belongs to the TechnoMaster, if you load another price list created by us (then the positions that are already associated with other suppliers will simply be deleted and this will lead to the fact that the supplier needs will process completely (associate with others and then scatter by category and brand in the list of products.) And this is 1589 positions for Technomaster today.
18.01.2021, 11:20
Well, you don't update the supplier's availability text - that's why the old text "In stock" is written. But the presence checkbox is actually not worth it.
Why did you set the "Do not specify Out of stock for products that are not in the price list" setting?
18.01.2021, 16:19
Administrator wrote:
767453
Excuse me, did not understand what checkbox and settings are we talking about?
19.01.2021, 10:38
see System settings
you have a setting that prohibits affixing products that are not in the price list with the presence of "Out of stock"
remove it and try to import data
19.01.2021, 16:18
see System settings
Where exactly in the system settings, above the tweaks is there!
26.01.2021, 11:20
If about this setting
She is turned off.
26.01.2021, 15:08
The question is still open
28.01.2021, 15:11
