Connected call script functionality, set it up
https://rozpakui.crm-onebox.com/admin/callscript/2/constructor/
The test process on which it is configured
https://rozpakui.crm-onebox.com/admin/customorder/lead/709803/edit/
We began to understand how this functionality works, made a list of edits (perhaps some will work without modifications).
1. Header [file]1039[/file] of the script name should not be duplicated.
2. There are stages, each stage has a name, if the first stage of the script is called as in the example Establishing contact,
it is highlighted in some color and only when you click on this button, the text and answer options pop up.
[file]1040[/file]
3. If I double-click on the option - the result is constantly duplicated - this should not be - if I clicked on the option
the text should pop up and then the next option (if available) If you need to change the answer, and click on the second option of this block, then the result below should be overwritten, and not duplicated
Connected call script functionality, set it up https://rozpakui.crm-onebox.com/admin/callscript/2/constructor/ The test process on which it is configured https://rozpakui.crm-onebox.com/admin/customorder/lead/709803/edit/ We began to understand how this functionality works, made a list of edits (perhaps some will work without modifications). 1. Header of the script name should not be duplicated. 2. There are stages, each stage has a name, if the first stage of the script is called as in the example Establishing contact, it is highlighted in some color and only when you click on this button, the text and answer options pop up.
3. If I double-click on the option - the result is constantly duplicated - this should not be - if I clicked on the option the text should pop up and then the next option (if available) If you need to change the answer, and click on the second option of this block, then the result below should be overwritten, and not duplicated
